Where do I go to find out if my new company name had not been used
SOURCE: Resetting the name of company and telephone number on fax sheet
Welcome to FixYa! I'm the expert that chose your issue to resolve. Now let's get started. Office machines, for whatever reason, seem to be a lot more complicated than the ones you use at home. But, this should be an easy problem to fix. The process of putting in your required and company information is known as "registration" To complete your registration do the following:
Note: if you want to check that what you put in is what you want, you can print user data list. Here's how:
(information above from Canon)
That's about it....I imagine that in a busy office, it's hard to find time to read through a book just to do this stuff, but I have the time.
Thanks for using FixYa.com!
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
SOURCE: change name that comes up on display phoned
Name programming requires access to system programming. If you go to the main phone and, without picking up the handset, press PROG and dial **1234 and ENTER, it will go into programming mode. Dial 004 and you are looking at the Ext Name screen. An ENTER at this point starts at 101 OPERATOR (default). Now just start pressing the letter keys and the right arrow to spell out the names. The keys press 7 times for ABCabc2. Punctuation and special characters are under the 1 and 0 keys and STORE or ENTER saves your work.
When I install my systems, I let everybody have access to the programming by class of service. You may be able to program from any phone in your system, it depends on the installer. The phone that rings when you dial "0" is probably the main phone if you can't program this from your own phone.
PROG exits programming.
Carl
SOURCE: company name and the serial name
try www.keygenguru.com for the company name and serial no.
enter "nero 6" in the serach box
SOURCE: I need to change the old company name to the new one
Here is a link to the users manual. You just need to change the registration information.
http://usa.copystar.com/americas/jsp/upload/resource/13716/0/FAX-SYS-L-ENOG.pdf
SOURCE: need to change user name and domain on Outlook email account
You cannot modify your existing ActiveSync partnership.
You must go into ActiveSync options on your phone and delete the partnership.
Note that deleting the partnership only deletes the copy on your phone. It will not delete the source mailbox on your server so don't worry.
Once that is done you can set up the new partnership with your new server.
I hope this helps.
