The laptop if older than 2009 , (NO PC stated.)
will have bad CCFL back lamps.
remove the big battery now,
run on AC pack only
still dead screen?
the fan must blow, seen/heard or better felt.
if fan is dead PC needs service, ask
if fan blows test the screen with a flashlight in dim room.
if you see data now, with the flashlight, the CCFL tubes DIED.
the first Aspire was made in
1999 when the Aspire 1151
2 decades of PC , made and vast submodels.
SOURCE: Acer Aspire 3100 series. Display screen getting dark
This is such a user error. I had the same problem on my 3100-1718. It was as simple as holding down the Fn key and using the left and right arrow keys to change the brightness... I am a goofball for ever letting this stay dark for a month !
SOURCE: ACER ASPIRE LAPTOP 2920 NO DISPLAY
Ckeck if your adaptor has power on the connector to laptop.
Might be damaged power cord (to and from the adaptor) or broken adaptor.
While there was power in the battery, it was running, but not charging.
Now the battery is emty and can't be charged because of broken adaptor/cables.
If you find there is no power from the adaptor, bepair it or buy a new one.
Do not try to repair the adaptor by yourself if you are not a technician, it is DANGEROUS !
Either give it to a qualified servicer, or betteer, buy a new one.
Regards.
SOURCE: laptop display drivers acer aspire 5920
Go to the Acer WEB site to download the drivers you need, make sure it is Windows XP or Vista version for your particular MODEL laptop.
Use this link :-
http://global.acer.com/support/download.htm
SOURCE: my laptop acer aspire one AOA 150 1570 , no display i dont know w
Try this repair, the BIOS most likely needs to be reflashed. You will need a flash drive and the BIOS files from Acer support downloads. Takes about 10 minutes for this repair.
Acer One Black Screen of Death Repair…..
In most cases the black screen of death for the Acer One is due to a bad update or corrupt BIOS. In 90% of the cases, this black screen can be cured by flashing the BIOS of the Acer One.
The first thing you will need besides the netbook is a flash drive, preferably a 1 GB version so you have plenty of room. Make sure it a flash drive and not a reader or mp3 player.
Go to the Acer support site and go to service and support and go to the drivers download section. Navigate to the exact model of your Acer One, it will be labeled on the bottom of the case. It will be something like AOA150 etc….
Once you choose the model, choose BIOS and download the latest that is listed. Save it to a folder on the desktop so you can find it later. Now find the file and unzip it to that folder. When the files are unzipped they will all be listed.
Now go to “My Computer” in the control panel and find the flash drive listed. Right click on the flash drive and scroll down to “Format”. Choose “FAT” as the format….not fat32 and not ntfs. Run the format, hit apply and accept and the flash drive will be formatted to the “FAT” file system, this will allow it to boot your computer and flash the new BIOS.
Now go to the folder that has the unzipped BIOS files. Now find the folder named…. “Dos_Flash…open this folder and you will find the file that has the version number of the BIOS files needed to flash the BIOS. Right click on this file and scroll down to “Rename”, choose rename. You have to change this file name to the following…..zg5ia32.fd
Now, copy this renamed file to the flash drive that you previously formatted and also copy the file, Flashit.exe to the drive as well. This file is in the same folder as the one you previously renamed.
Now make sure the netbook is off and is fully charged. Now connect the flash drive to any of the available USB slots. Now, press the “Fn” key and hold it as well as the “Escape” key and hold it. Hold these two down together and do not let go of them. While you are holding these two keys down, press the power button and hold it down until you see the green power indicator light comes on and starts blinking…once this happens, let go of the other buttons and observe the indicator light on the flash drive. It should also start blinking indicating files being read on the flash drive. Now, just wait up to 1-10 minutes for the BIOS to be written and flashed. If it all goes well…..the system should boot up without incident and without any data loss.
Hi dongare amol, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
still dead screen
what model of Aspire, 100s there are.?
