OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
hi
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
SOURCE: LG dishwasher with error code OE
Drain Error OE
Not fully drained out in
spite of 5 min. drain
operation
The Drain Hose kinked or blocked.
Wiring connection is OK?
The drain outlet of sump is
blocked.
The Drain Pump/Motor or circuit is
troubled.
Remove the cause of kink or block.
Check the wiring connection.
Measure the electric resistance of
Drain Motor. (20-40 )
Replace the Drain Motor or repair
the Circuit.
