These machines have alot of computer board issues,unplug the dryer,go in the back where the cord connects to the block,check the wires to see if they're tight and wired correctly,if it is i would have to say you have a bad board,the only way to tell is by checking with a meter to see,before this happened did the dryer make any beep sounds or anything like that,i've seen them beep and then start up on there own,or has any error codes ever come up,also how old is the cord?if the cord is old it could just be the cord.
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
SOURCE: My dryer has started running
It could be a problem with the drum rollers or the jokys. How old is the appliance?
Check the door switch. It may be at fault here. Open the door and hold the switch by hand and start the dryer. The switch should have a firm resistance to it when you push it. If you should find this bad, here is the replacement switch. If the switch is ok, then the motor is bad. Here is the motor to order.
Keep me posted!
