The brushes are not replaceable - it is an entire motor assembly.
1) remove the 2 screws holding the top handle on
2) remove the 2 screws on the top of the housing (front either side of switch)
3) remove single screw holding cord hook (rear side of housing)
4) remove small torx screw in the shaker handle and remove the handle
Flip over and using a screwdriver begin to pry the top cover off the housing (easiest to get the front side off first)
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
SOURCE: change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
SOURCE: looking to buy a manual for a porter cable nail
Go to Dewaltservicenet.com and type in your model number the manual is 13 pages long. If I have helped you with your request would you please rate this response accordingly. Thank you
SOURCE: Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
SOURCE: My Porter Cable polishing machine slows down when used
Yes, probably the brushes are worn down.
