SOURCE: Ricoh KR-5 light meter needle won't move, new batteries
About the only thing you can do is clean the batt. cover and contacts in batt holder. Make sure batts are good. No parts are avail. for this model. However this is a rugged camera and you can buy a hand held light meter inexpensive.
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
SOURCE: batteries not charging - just replaced
1st Check the 25amp inline fuse located behind the volt meter. 2nd Check the 50 amp fuse located behind the foot rest. A pin located under the foot rest when pulled out will open the front to access the fuse.
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
SOURCE: need a wiring diagram for jet 3 power chair
Look here: http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_ultra_om.pdf
