That sounds like a voice command problem for this Chicago, Illinois based channel. Refer to the station by its number on your subscription package, like "Alexa channel 1105 on tv".
Samsunghttps://www.samsung.com > answer > ANS00087622
Amazon Alexa is now built-in on Samsung TVs and smart monitors! You can ask Alexa to change the channel, open apps, search for movies and shows, play music, ...
Tom's Guidehttps://www.tomsguide.com > How-to > TV
Apr 5, 2023 - Step 1: Set up your devices. First, make sure that both your Samsung TV and your Amazon Alexa device are set up and workings.
Can Alexa change TV channels? As long as you're using the TV's built-in tuner, you can use Alexa to change TV channels. Just say something like "Alexa, channel 7 on TV" or "Alexa, change channel to [channel name] on [TV name]."Nov 1, 2022
Not sure who you are talking to in the 'Additional Information' box below your question. You may have be talking to an AI Answer Bot which has had its answer deleted. That box up there is for Experts to ask you for further information before committing to an answer. The correct way is to click Comment under the Answer you are replying to.
You are now prepared to use Alexa.
To get started, open the Alexa TV app on your Samsung TV.
You are able to utilize Alexa now that you are connected.
You will have the option to activate Alexa Hands-Free if it is offered.
Consider utilizing Alexa.
Your Alexa-enabled device doesn't connect to your Fire TV. Make sure that your Alexa-enabled device and Fire TV are registered to same account. Check that your Alexa-enabled device and Fire TV are on the same Wi-Fi network. Make sure that your Fire TV and Alexa app have the latest software version.
Many cause behind that for Alexa Not connecting to Fire TV
Loose connection for Alexa Setup device and Fire TV
Wi-Fi connectivity issues between Alexa and router and smart phone
Alexa is may be the switch mode
Alexa App not updated
Alexa firmware not updated may also arise the problem during connectivity with smart home device
Lastly: you need to fix the above problem or contact the Alexa expert and get the solution for Alexa Won't connect to Fire TV.
As different TV configurations demand different setup procedures, figuring out the first step clearly demands paying attention to the type of TV and related setup. You can find a variety of YouTube vidieos about specific TV setups. Additionally, here are some aids:
