Hp c4480
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
SOURCE: HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
SOURCE: printer goes through motions to copy doument but pages are blank
From Kodak's website:
Question :
Why are prints from my all-in-one printer blank?
Answer :
There may be multiple reasons why your prints are blank. To resolve this problem, we have an easy Step-by-Step Solutions and Repair tool.
Within the tool, select Print quality, then Blank prints.
Start @ this link:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=10355
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Blank copies
Thanks Guest with Best Solultion! OMG! I have had my machine printing blank for over a month now and reading stuff and trying to find a solution. Until finally today I found this page. I read your solution and hit the front like u said for several times and nothing. Finally, after the third try WALA...IT WORKED!!! Thanks again. If anyone has this same problem try this because it really works! Eventhough this is such a strange problem for such an expensive machine.
