What is the model number?
Link to discussion of beeping at the web page below:
Our Liebherr fridge freezer won stop beeping advice
SOURCE: fridge stops working when power goes out.
Good possibility that the electrical contacts have failed (burned/welded) in either the defrost timer (part# 68233-3) or the Cold Control (part# 61002085. An intermittent failure is extremely difficult to track down. Both of the parts I listed total about $80. You can purchase them and install them for less $$ than having a professional do it for you. We would obviously charge more because we would absorb the cost of warranty, labor, drive time, etc... If you choose to replace these components, UNPLUG THE FRIDGE BEFORE HAND!
SOURCE: We just experienced a power outage and now the
try unplugging it for five minutes an then plug it back in the default settings should appear
SOURCE: alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
SOURCE: Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
SOURCE: Frigidaire fridge will not stop beeping and will not turn on
The only thing that I know could be causing the problems is the=> 5303918476 Defrost Control Board
This part is behind the control panel inside the fresh food section where you adjust the temperatures. Let me know if you have questions, Thanks Sea Breeze
You obviously have the wrong model number listed on your post. ?? What is the correct model number listed on your model? The model mentioned in your post has mechanical thermostat and yours has didital.
