It showing red light and showing u4
Http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
SOURCE: xerox 214
That is a fuser overheat message.
You can try this. Enter diagnostics. To do that turn the machine off, then press and hold down the ( 0 ) zero button while you turn the power on.
Once the machine comes on in diagnostics. Enter code 40 1and press start to see if it clear the fault.
That is enter 40 press start then 1 press start.
If that does not resolve the code you need to replace the fuser.
SOURCE: U4 error code - Xerox 5328 copier
U4-2
Low fuser temp problem
U4-3
High fuser temp problem
U4-4
U4-6
replace thermistor in fuser unit
SOURCE: My Xerox Workcentre-5020 machine showing
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
SOURCE: my machine Xerox Work Centre
my machine xerox 420 problam is U4
plz tell me the how to reslove this problam
