What will happen to my aeg water heater i will remove the reset bottom can i still use it pls help?
You do that at your own peril. That reset button is what keeps the water from overheating if the t-stat has failed. Change both upper and lower t-stats. If the heater is older than 10 yrs, then you may be better off spending money on a new htr because the average lifespan of a wtr htr is about ten years.
SOURCE: I have an AEG Undersink water heater installed.
Check the voltage supply if it is good the the unit is bad
