Watches Logo
M
Marlene Hallam Posted on Feb 19, 2018
Do you still tracksuit top number 38773 XL in acqua
Lost my Acqua Indiglo Digital wristwatch User's Manual...how can I get another?
Acqua watches are made by Timex. For a manual for any model, go to https://www.timex.com/watch-manuals.html
and choose your watch.
I have the Ladies Wall Street watch with the beige color leather strap. A red velour tracksuit rubbed some red on the band...how can I get it off? Thanks for your help! NancyMacNeill
Hi nmac1009
The most common way to remove any coloured spot is to gently rub it with some spirit or petrol.
You can take a earbud. Dip it in gasolene or petrol.
Squize it.
Then gently and very carefully rub it on the red spots.
Note: Be very careful while doing this.
Better you first check that it does not remove the original color of the leather strap.
Then only go ahead.
Hope this helps.
I received a used Acqua Indiglo watch recently which appears to work but I have know idea how to set the functions. How can I attain a manual? Thank you
This web page explains how to set the watch:
http://wiki.answers.com/Q/How_do_you_set_time_on_a_acqua_indiglo_30m_watch
Also, if you google "Acqua Indiglo manual" you will find many other articles that explain how, in case that one doesn't work (but it should).
Hope this helps.
Dec 15, 2010 • Watches
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
I NEED THE INSTRUCTIONS MANUAL FOR AN ACQUA INDIGLO MEN'S WATCH. hOW CAN i FIND IT?
mcdevito75 here, You can visit Acqua Indiglo.com or check with a small watch repair shop in your area.
I need an instruction manual for an Acqua Indiglo digital mans watch. There is no model number on this watch. It has 1 button on each side of the case that are caddy corner from each other. On the front it...
Go to Timex.com and see "manuals" at the bottom of the screen. You can download the manual for the acqua and expedition series of watches.
Thanks!
Sep 22, 2009 • Watches
3helpful
2answers
Acqua Indiglo watch
Can't understand instructions
Aug 31, 2008 • Watches
88helpful
5answers
Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Jul 25, 2008 • Watches
10helpful
Timex Indiglo Acqua watch
For analog Acqua watches adjust date when month has less than 31 days:
3-Position Crown: Pull crown to "MIDDLE" position and turn CLOCKWISE or
COUNTERCLOCKWISE until correct date appears.
2-Position Crown: Pull crown to "OUT" position and turn CLOCKWISE until date
changes (approx.1:00 a.m.). Then turn COUNTERCLOCKWISE to 7:30 p.m. Repeat until correct date appears.
Dec 05, 2007 • Watches
Top Acqua Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you an Acqua Watch Expert? Answer questions, earn points and help others
