Sewing Machines Logo
T
Thomas Posted on Feb 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My necchi sewing machine model 523 is not picking up thread
R.A. Ellis
Level 3:
  • Necchi Master 12,731 Answers
  • Posted on Feb 19, 2018
R.A. Ellis
Necchi Master
Level 3:
Answers
12731
Questions
Helped
2613459
Points
59176
Try a brand new needle. If that doesn't work, then the machine is probably out of time. Search for sewing machine timing or take it for service.
5 Related Answers
Anonymous
  • Posted on Nov 09, 2008
SOURCE: necchi 3101
if you have e-mail I can scan and send you the diagram.
Mimito7
Kelley Buchanan
  • 130 Answers
  • Posted on Apr 22, 2009
SOURCE: Necchi Heavy Duty Sewing machine model 3205FA,
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Anonymous
  • Posted on May 06, 2009
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
happyman70
Sonia Bennett Murray
  • 4 Answers
  • Posted on May 27, 2009
SOURCE: thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
ken dourof
  • 980 Answers
  • Posted on Jun 09, 2009
SOURCE: how to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
How to thread the 525fa necchi sewing machine
You can buy a manual here. Probably worth buying if you're going to learn how to use your machine.
https://www.sewingpartsonline.com/necchi-sewing-machine-instruction-manuals.aspx?sort.ss_cat_sort=desc&index=our1
These videos may be helpful. Although not your specific model, but most machines thread similarly.
How to thread Necchi model 535 FA sewing machine now with captions
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Necchi model 3537 won't pick up bobbin thread
sewvacdoctor.com has a list on their site with helpful free tips. I found this site for you I think will get you on your way. Hope this helps.
Where can i get my sewing machine fixed? i have a Necchi sewing machine, and it does not work. i bought it two years ago and it was working perfectly. i've tried everything it said in the manual, but it...
make sure you have it threaded right and picking up thread at bobbin
brfore sewing i have seen a lot of people put the thread the wrong way through the needle and it will have this problem
Top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
