Model # RF28HMEDBSR Serial # 065L43BJ05889K
Samsung refrigerator error PC Ch means a wire harness error. Verify that the wire harness under the top left door hinge is connected properly. The Samsung manual tells you to check ALL wire harness, as one is not connected properly or is damaged. Samsung Refrigerator Error Fault Codes How To Reset
SOURCE: Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
SOURCE: Clicking of Ge Model PDS22SBRBRSS; serial No; AHO45649
Replace the mother board. It is only a matter of time until you experience cooling issues.
SOURCE: Have brand new APC 900 UPS and when plugged in,
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
SOURCE: ICE MAKER HAS STOP WORKING IS THEIR A WAY TO
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjgkjgkj
SOURCE: I have a samsung over
Hi SE error code means shorted key and is displayed when either
a key is shorted or the key pad has gone bad. Usually replacing the keypad
solves the issue however, before doing this you can also try to leave it unplug
for 15 minutes. If the issue returns then the keypad should be replaced. Hope
this helps...please post back for further assistance. Daniel
