Cut the original wire harness....checked for12v constant...checked for ground...and 12v accessory...but not sound...help please
SOURCE: instaling alpine car/cd stereo cda 9807
how do i install my alpine cda 9884 ...on a 92 caddi
SOURCE: cut harness from stereo in 1990 corolla dx sedan
did u know that they make a harness for your car that plugs into your factory harness and then adapts to your aftermarket radio? for the lights, you have blown the interior light fuse, it may be the same fuse as the cigar lighter.Below is your radio wire colors and what they do.
1990 Toyota Corolla Car Stereo Radio Wiring Diagram.
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Rear Speakers Size: 4′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
SOURCE: wiring for radio 1993 toyota corolla
You likely blew a fuse for your lights. Here is a wiring diagram for the original radio.
SOURCE: Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
