I've been fighting keyboard errors for almost two months. This was finally SOLVED by ordering a SECOND replacement keyboard! The first replacement keyboard was faulty too with the similar errors. Now my ASPIRE keyboard problems are over!
SOURCE: acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
SOURCE: Acer Aspire 3050 keyboard issues
go to my computer, right click, properties, device manager, look down list for keyboard, click '+' sign, you will see your keyboard listed, right click select uninstal, then restart notebook it will reinstall itself and should be working as normal.
SOURCE: replace keyboard on Acer Aspire 5515 laptop
Click this link it is basically the same. Let me know if you find a keyboard:
http://www.powerbrixx.com/reference/acer/3610_keyboard.htm
SOURCE: Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
SOURCE: how to replace a acer aspire 5735 keyboard
Here is the factory service guide that explains complete servicing of the laptop. Make sure to save a copy for yourself, the file is free to use.
http://tim.id.au/laptops/acer/aspire%205735%205735z%205335.pdf
