SOURCE: TV is approx. 10 years old. Picture has started
This is a model first made in 2001--when it does it go into the customer menu and select CONVERGENCE--what you are looking for is is red or blue skewed and will not adjust?
If this is the case I can tell you what is needed based on the model number you provided.
If you have any questions let me know--I am here to help people.
if this helps you rate this information as I do this here for FREE.
SD TECH
SOURCE: TV will not turn on.
Same problem with mine. This is a typical problem with this television. You need to replace swollen capacitors on the power board.
SOURCE: I have an older Kenmore.....Model C110 753702
I don't believe the control assy. is the problem, I would be more apt to think the drain impeller could be broken in the drain pump or there is something stuck in it.
