I've simply added other 3 Hdd into the empty slots available and configured them with IBM SERVERAID MANAGER as a 2nd array to verify if they are status ok and properly working. After that I do not need them anymore and thus removed them from ibm serveraid manager and then phisically. After that the server doesn't boot without the hard disk previously added. How can this be solved?
If you can get into the bios, you should be able to tell your system which drive(s) to boot from.
Testimonial: "In case that's not possible from the bios what about the following way: - Turn on the server regularly; - Once in win2k3 open the Serveraid manager, take the hdds not needed anymore out from the slots and then copy the configuration from drives to the controller ; - restart the server to verify correct boot."
