I don't have information on this so can you tell me what maintenance may need to be performed and how to reset this program. Thank you Gerry Beard
SOURCE: Remove Oil maintenance required message on 2008 Toyota Highlander
This is the reset proceedure for a 2008 Highlander with a key-type ignition:
Turn the key ON, do not start the engine.
Look at the odometer, and verify that it displays "TRIP A". If it is on "ODO" or "Trip B", press the black stick next to the odometer to read "TRIP A".
Turn the key OFF.
Press in, and HOLD the black trip meter reset button, hold it IN.
DO not release it.
Observe the Odometer display. You will see 5 dashes, then 4, then 3, then 2, then 1 dash, and finally, 5 zeros. Then, whatever number that was displayed on "TRIP A" will be re-displayed..
Now release the black trip meter reset stick.
This completes the reset procedure, and it will be back on in 5,000 miles, to remind you of you next oil change.
Hope this helps! Thanks for choosing FixYa!
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
SOURCE: How do I reset the maintenance required message on
With ignition off, press and hold "SELECT" and "RESET" buttons on dash and turn ignition to the "ON" position. Continue to hold until lamp resets.
SOURCE: "Time for periodic maintenance"
Go into (08) mode by holding 0 and 8 when turning on the copier. 251 is the number of copies until it displays that message and 252 is the count since last Preventative maintenance. Resetting 252 will clear the message or putting 251 higher than the value of 252 will clear it as well.
