Depends on your headphone. Just follow instructions on headphone manual and tv. Personaly i doubt you can pair bluetooth phones to tv directly, never seen b4. BUT, you can buy from ebay bluetooth TO audio adapter. There is ebay item number 222294284409.
Long story short, its rechargeable and works fantastic. Dont forget to follow pairing instructions.
SOURCE: can't connect wireless stereo to sylvania 6620LF4
Hi, Ok, I now understand what the problem is. Sorry I missed the fact that it is due to no audio outputs on the TV. The audio board is designed to power low impedance speakers and doesn't have a big power amp to drive them. I do not have a schematic of that particular TV so I do not know how the headphone jack is wired. The way it basically works is, when you insert the plug, the tip pushes a contact away from another contact thus making one circuit and breaking another. You can test this externally by inserting an unwired plug or look at it from the inside and bridge the tip connection. I would only advise this if you have some technical skills. Other than that the thing is working like it was designed, they don't want you to use both. Sorry, I hate to give this type of news, but I am one of the only ones who will. Good Luck to you!
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
SOURCE: how to hook my philips cordless headphone SBC
http://www.p4c.philips.com/files/s/sbchc070_00/sbchc070_00_dfu_fin.pdf
is the link you must use to get all information you may need. copy and paste the above link to your browser. Good luck Don't worry about the model number.The principle in which they all work is the same.
SOURCE: i bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
