Question about Hisense 55 2160p LED Ultra HDTV Class 4K Smart TV WiFi Television 55T880UW
Hisense TV just stopped connecting to wifi. All other devices fine. Tv connected for over a year now wont even find the network to connect to. Download speed is good. Reset modem but cant fond how to reset the TV.the 2580 instructions dont work
The problem is to do with the TV's cache. I do not know why, but after you go to System and empty the cache, restart the TV, everything will work. I suspect the cache is too small
Posted on Jan 03, 2019
  • 1 more comment
  • Peter Minstrel
    Peter Minstrel Jan 03, 2019
    you will have to login to Netflix again (and perhaps to other accounts)
  • Abel Simunji
    Abel Simunji Mar 31, 2019
    Peter you are the MAN thanks, it worked.
  • Peter
    Peter Apr 20, 2019
    worked for me too, thanks
Unplug your TV power and then plug it in again. It will then connect to your WiFi that you already had set up. I have to unplug the power about every 3-5 days. No idea why, but it fixes it.
Posted on Nov 24, 2018
  • Bill Auld
    Bill Auld Jan 19, 2019
    worked first pop. Amazing. been fiddling with set up for months .should have come here sooner. thanks.
SOURCE:
simplemitch
  • 752 Answers
SOURCE: hp zd8000 vista wifi problem
Is your WLAN turned on? It's usually a switch or button somewhere on the machine with the WiFi icon around it. Kind of like this:
(( i ))
Posted on Aug 05, 2008
SOURCE: I have network connected my internet works
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Posted on Aug 29, 2009
  • 109 Answers
SOURCE: How do i get my 32 inch hisense tv to connect to my wifi? It says connected but not connecting.
I have a 1999 Alero, and yes it is under the hood in a black fuse box, slot 34, 20 amp.
Posted on Oct 17, 2015
AndrexT
  • 26370 Answers
SOURCE: I lost my remote and I can't get to my WiFi network how do I reset my 32inch hisense TV
First, how can you 'lose' a remote control?
Second, what does your television have to do with you getting on wifi?
Google
Hisense replacement remote control
You Reset most things by disconnecting from the power for 10 minutes.
Posted on Jan 18, 2017
SOURCE:
Could be a corrupt Wi-Fi receiver module, before you rip it apart if it’s not under warranty.
Buy an external USB Wi-Fi adapter and insert it into the TV see if that resolves the issue.
Unless your an electronic geek or you have the electrical diagram you really won’t know what the WiFi unit looks like or if it’s even a detachable board. It maybe built into the entire circuit.
Posted on Dec 14, 2017
Trying to connect wifi to hisense smart tv ssid wifi connection. I put in the password for access point connection and it either says timeout or connection failed. Any suggestions?
plug in the eithernet cable while you try to connect the wifi and after it's working remove cable and try the wifi, I have a printer where the cable needs to be connected while installing the wifi and after working remove cable and works fine..
Sep 23, 2018 | Smart Computers & Internet
I have a hisense tv 32” how do I connect to wireless wifi
This would depend on the model and whether it was a SMART TV.
The internet connection is via a LAN cable or via your satellite or cable box to your Home Network. Your smartphone connect to wifi and via that to the television.
Feb 05, 2018 | Hisense Televison & Video
Hisense roku tv wont connect to wifi today
Unplug the device and try again after 5 minutes, also reset the router.
Nov 10, 2016 | Hisense Televison & Video
I need help on how to connect the network on my Hisense smart tv. I don't know the model number or how to find it.
Does your TV have RJ45 connector ?
That looks like
26263581-kbmxcsgdcjwkxkxfv11waner-3-0.png Insert a RJ45 patch cable from the router to that port using taht looks like this
26263581-kbmxcsgdcjwkxkxfv11waner-3-2.png Your TV should AUTOMATICALLY now be on the network
Aug 20, 2016 | Hisense 40" Smart TV Full HD 1080p LED...
How can I connect my hisense tv to wifi? it wont show my wifi name in security mode. when I scan it says no ap?
Either your router is not set up to broadcast the SSID(network name),the router is too far away from the TV, or there is a problem with the wireless on the TV.
If you can see the SSID from the same location with your phone/tablet/etc then it is probably an issue with the TV. You can also check for a firmware update for both the TV and the router.
Nov 16, 2014 | Hisense Televison & Video
How do I connect my TCL Smart TV to my Wifi network?
Check your router to see if the MAC Filtering feature is in use. If it is then you will need to add the TV's MAC address to the list of permitted devices before the connection will complete.
Aug 26, 2014 | TCL L32D20
Come across a really annoying problem within our household. We're with TalkTalk for internet, i'm on a PC connected via WiFi through a dongle on the network. There's also a TV that is causing the...
Ok. (I don't know how much help I can offer since I'm in USA and you're in UK). 1) From what little I was able to look up, TalkTalk Internet is really small and has a lot of issues regarding on what it delivers to it's customers. 2) The HUAWEI HG533 Router... (from your description of the symptoms with your TV), seems functioning ok, just that the Bandwidth (Internet speed of your ISP-TalkTalk) is too slow to keep up with everything you want to do once you add the Video for the TV. IF you use the Internet cable from your router to the TV, you should have a Faster connection for internet reception (compared to WiFi. Minimum of N-Band on WiFi should suffice for 1 TV and 1 Computer. 5 Devices or more, I recommend a Better Router and Cable your Devices that need the Fastest connection for response, IE. 1-2 computers, TV or Blu-Ray device that provides content to your TV). Best advice - Inquire your Internet Provider about your situation, Possibly change ISP's, Make sure your Router can handle the Usage on WiFi and Cable connect that you require. I have been using a D-Link DIR-655 N-Band Gaming Router (broadcasts WiFI @ 65Mbps/sec, 4 cable connect Ports with 1Gbps speed) for several years now. I've got 2 puters and a Blu-Ray device cable connected, we WiFi our 3Cell phones, a Sony WII and 2 other puters for our kids. We pay a about $25 more a month for faster Internet speed, all runs rather well (Time Warner Cable Turbo, USA, total Internet cost is $65 a month, we don't subscribe to any tv or land-line phone, since we use cell phones).
Jun 20, 2014 | Computers & Internet
WHAT IS THE PROTOCOL FOR HISENSE TV HL24K20D
"On the Hisense TV sets there is a Digital Coaxial audio output available on the side of the TV set ... The Dynamic Host Configuration Protocol (DHCP) is a network protocol used to configure devices that are connected to a network"
http://www.hisense.co.za/support/faq_tvs.asp
May 08, 2014 | Tablets & eReaders
Hisense 55 2160p LED Ultra HDTV Class 4K Smart TV WiFi Television 55T880UW Logo
7,777 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
