Toll free helpline phone number is +1866 94O OOO5
Either you have your controller upside down, or there is something in the settings that have it set for inverted controls. I do believe you can also reset the controls in the settings as well. Maybe someone changed them?
SOURCE: 1997 pontiac sunfire manual transmission won't shift out of gear.
What you can try is to remove the shift cables from the transmission side. then move the shifter and see if everything is free if it's still sticks then the cables are going to be replaced. if everything is moving with the cable off. then you need to remove the shift tower on the tranny (where the shift cable is I belive it's 5 bolts) remove the tower and you will see the shift pin. Inside the tower there is a cotter pin that breaks and that will cause you to have one gear and unable to selected another gear. If you are not mech inclined I would no attemped the shift tower repaire, the cables do it will save you money. The shift tower has bushings that can fall into the tranny.
SOURCE: gear select lever is very loose. It move forward
There is a pin that goes through the shifter that hold it in place, along with a spring just inside where the end of the shifting lever is, that makes the lever "return" after you pull it back to shift. These springs can break and bind up. Take a look at both.
SOURCE: The electric front seats both stopped moving
Check the fuse box for a blown fuse, both seats may operate on one fuse depending on the model of vehicle and the fuse may be located either under the dash on the drivers side or in the engine compartment on the drivers side.
SOURCE: Driver's seat unable to move forward or backward
There are plastic gears connecting the track to the seat assembly. Whne one of these strip the seat will only work or move to one side. Infiniti does not sell a simple fix. You are looking at buying an entire seat assembly complete with the module for all the electronics. It will be at a cost of around $950 - $1000. Once that is in, Infiniti must program the seat to the brain of the car, only then can you reset your memory settings.
SOURCE: My front seat will not move forward. It will
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
