Contact Fingerhut Customer Service
Ask Fingerhut if they know of a source.
May find a used one on eBay. That model appeared to be manufactured in 2002, over 15 years ago, so it may be difficult to locate. I was only able to locate a similar named model on eBay, but not the same model number.
Chef Mark Stand Mixer With Bowl White 422AL10010
SOURCE: Stand Mixer
Model H was discontinued in the 70's. You might find beaters either directly from Hamilton Beach or on Ebay. There aren't many small appliance repair shops any more, everything now, is considered disposable.
SOURCE: My Kenwood Chef Mixer (Stand
You could contact
http://kenwoodchefrestore.co.uk/2009pro.html
Deborah
SOURCE: Mine is a Chef Stand Mixer but really don't know model no. Where to find?
This kind of unit are lubricated with grase paste. If the unit stays
inactive for a long time, or if the motor and gears are overheating the
grease paste gets melted into thin oil, and that will cause leaks.
To lubricate the unit, you need to spread again the grease in the gearbox, using special
foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous
experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users
from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
SOURCE: Replacement beaters
I called west bend about mixers for my stand mixer.Model number 41036. They said this model has been discontinued and they could not help at all!!!
SOURCE: I have a Rival-Chef Excel
I live in the US and have an old Kenwood KM230 Mixer that I absolutely love. Unfortunately I can not locate a replacement for the spashguard that has now cracked. The old splashguard item # 27215/31227 is the replacement spashguard....any solutions
