Machine model d-copia 18mf Olivette digital copier, hope you can share your comments and thoughts with this problem
Testimonial: "Thanks Fixya for some Tips in fixing some errors occurred on my machine d-copia Olivetti digital copier, it is great and useful, anticipate you kind support and immediate assistance. Code errors C6400 and C3200 has been succefully resetted according to your useful instruction."
SOURCE: COPIER GIVES THIS ERROR E0000-840-0001
this err belongs to sensor problem.
chech thermostat sensor
SOURCE: Error code E20 in Canon NP 6241 copier
Check this code - does it read E020 ? if so this is usually a result of toner starvation possibly caused by a faulty toner sensor in dev or hopper unit.I have also found the toner hopper supply motor can fail with the same result. In either case it is an engineers job to rectify. Good luck !
SOURCE: MACHINE REFUSES TO SCAN SHOWING ERROR EA3229 ON BIZHUB 200 COPIER
As with most communications errors the first thing to always try first is shutting off the copier, unplugging it from the power source for at least 30 seconds, then plugging it back in, powering up and trying the scan-to-email functions again (once network synchronization has been completed by the copier).
EAXXXX is a communication's failure code generated by the copier to state that 1. The LAN cable is not physically connected, 2. Communication with the SMTP server has been lost, or 3. One or more of the e-mail addresses that someone attempted to send mail to doesn't exist or is invalid.
If the scan-to-email functions worked before this and have suddenly stopped, you may want to have your IT department reset the mail server.
It's also possible to have had some changes made to internal network address that has affected the copier's ability to communicate with the servers. Check with your IT to see if they've added any security software, changed network address structures, etc., around the time that the scan functions failed.
SOURCE: Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
SOURCE: Canon iR2318L digital copier/printer is showing
hello,
you need to change the fixing film in fixing unit! The fixing film is worn out!
There is no reset for these type of error! Call service!
Hope that helps!
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON
again while holding down the Utility/Counter key more than 10 seconds
after. A screen will appear saying "TROUBLE RESET"
3. Touch "TROUBLE RESET".
4. Check to make sure that "OK" is
displayed below which confirms it has been reset.
If "OK" is not there , it will show a different
code....
IF it says "OK", you should be good to go. Error
code should now be cleared.
5. Just Turn off the Main Power Switch
wait at least 10 seconds....and turn it on. Make sure that the machine properly
starts.
** If it re-displays the
code again within a short period of time, replace the fuser unit. Or get a
certified technician to replace the or adjust the sensor or Thermistor unit.
However, since you just purchased this I will assume that it is either a defective
unit from manufacturer, or the company who rebuilt it did not properly ensure
it was working. Return it and demand a replacement in EITHER case!! J
Hope this helps
