SOURCE: Comfort zone infrared heater keeps flashing A05 what does this mean?
A05
code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Hi George Roberts, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Providing us the Model number helps in searching the internet for a solution. Can you tell?
One person with this problem wrote that their thermostat was set lower than the actual room temperature. When they turned up the heater temp, they said that fixed it.
Other people reported part replacement - which would require a technical repair person.
