I was watching tv and the sound stopped and never came back on. The picture is fine.
The Video (Picture) is SEPERATE from the Audio component of the TV. One can work when the other has gone south. From what I see, the Audio controller board may have been damaged somehow and needs to be replaced. Contact a serviceman for details.
Testimonial: "Thanx"
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
SOURCE: No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
SOURCE: LG 42PC3D Plasma: No picture, good sound
One of the SUS panels will be defect.On these panels you will find several fuses,the panel with the broken fuse must be replaced.
Sus panels are the panels with the big cooling blocks.
I had this problem before on my LG TV. My solution is to put a 12V fan on the tuner board processor. The problem is caused by the TV overheating and when the tuner CPU overheats it sends a high temperature OFF command that instructs the power board to shut the tuner board off (although the rest of the TV stays on). This is why it sounds like a click when it happens. You cannot likely get a TV repair man to fix this because the LG TV's do not have adequate heat control other than vent holes on the bottom and top. This is a design flaw that started a class-action lawsuit against LG.
My TV has the sound problem as well!
