Uniden Cordless Phone Logo
K
Kathleen Foran Posted on Feb 15, 2018
Can you block a silent number on landlines uniden cordless
If so how do i do it i have forgot and have misplaced ed ybook
  • astrotirph10 Oct 07, 2018
    Probably not. That is controlled by your phone service company usually on blocking anonymous callers. Make sure when you sign on for land lines that you have all of those options included in your quoted price. You can also look the company up on utube for info. Good luck!
astrotirph10
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 4 Answers
  • Posted on Oct 07, 2018
astrotirph10
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Problem Solver:
Answers
Questions
Helped
595
Points
If I get desperate I open the phone with small screwdriver and pry it open. Undo internal battery replace and if that doesn't work I've reset the brains by clearing inside dust and pressing buttons with screwdriver tip to sort of short circuit and reset the brains! I figure it's not working properly anyway it might ! It did.
5 Related Answers
Anonymous
  • Posted on Mar 07, 2012
SOURCE: how do you turn off silent mode on Uniden DECT 6.0
In standby mode pressing and holding # brings up the "Silent Mode" special feature .. unfortunately the only options are to set the time for the device to be in silent mode and no way to turn if off. The solution is supposedly to press the # key again and hold it down, but this does not work either. The only way I can manually return to not be in "Silent Mode" is to reset the base unit!!
  • 6688 Answers
  • Posted on Jul 01, 2011
SOURCE: how do you trn a uniden D1660 cordless phone off
To exit the silent mode, press and hold # on the handset for about 5 seconds. In the future, when you set the silent mode with this press and hold routine, you can follow it by a number (1-9) to set a specific length of time for the handset to be silent. Otherwise it will stay on until you manually turn it off.
The manual for the D1660 is available from http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf .
I hope this helps.
Dave Ellis
  • 84 Answers
  • Posted on Feb 26, 2010
SOURCE: I have a Uniden 6.0 DECT cordless phone. Misplaced the manual.
Since you dont list which specifc model you have, I cannot list the specific manual. But here is a link to Uniden's list of manuals, you should be able to find yours here. http://www.uniden.com/index/manuals_results.cfm?cat+1
Anonymous
  • 10 Answers
  • Posted on Jul 19, 2009
SOURCE: forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Anonymous
  • Posted on May 15, 2011
SOURCE: how to take silent mode
To turn off silent mode, press the "#" and hold down until it changes. :)
How do you turn silent mode off?
How to turn off the silent mode - YouTube
? 1:01
https://www.youtube.com/watch?v=4aTYi1exVlw
Jul 29, 2013 - Uploaded by carlos67538
Turned on Silent Mode and forgot how to turn off! I appreciateyou took ... BTW you come up first in a google for \Uniden Dect 6.0 silent mode/ !.
How to turn the ringer on and off U
How do I get out of silent mode on uniden dect 6.0
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1760om.pdf
1. With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
2. To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.
3. After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
How do l turn off silent mode
For most Uniden 6.0 cordless phone handsets, you toggle the silent mode on or off by pressing and holding the # key. (When you turn it on, you can then enter a number to set the length of the silent period.)
Please add a comment with the model number of your cordless phone if this doesn't work. I may be able to give you the correct method to exit silent mode for your phone.
I hope this helps.
2answers
Silent mode on how to take this off
Search your Uniden model number online and they will have instructions for your phone.
How do I get out of the silent mode on my new phone? CID:I 9. I misplaced the instruction manual. thanks
Since you didn't state the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
12helpful
How do you trn a uniden D1660 cordless phone off of silent mode
I hope this helps.
1helpful
How do I block numers?
Without a complicated telephone system you cant block the numbers. Unless your carrier has some kind of service. Contact them.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
