Tools & Hardware - Others Logo
Tony Soanes Posted on Feb 14, 2018
1894 357 keep bending pin point on one piece why?
Gun only fired 300 self load 3.5 grains of unique since I fitted last one.
5 Related Answers
yoopertech
  • 131 Answers
  • Posted on Jun 23, 2009
SOURCE: when i fire the gun the drive pin stays out and
Your tool has been dropped and needs a new cylinder assembly and lower probe.
I`m a factory trained repairman.
Thanks!
Jeff
Anonymous
  • 86 Answers
  • Posted on Aug 16, 2009
SOURCE: I have a walther bb gun, need to find parts..
HI. YOUR BB GUN HAS NO FIRING PIN,,IT USES A SMALL TYPE OF RELEASE TO LET THE SPRING GO IF THAT IS THE TYPE OF BB GUN YOU HAVE. IF ITS THE (CO2) TYPE IT RUNS A LITTLE DIFFERENT BUT NO FIRING PIN. I HOPE THIS HELPS. JIMBO
Anonymous
  • 313 Answers
  • Posted on Sep 08, 2009
SOURCE: nailgun firing pin not connecting with nail
  • you need to make sure the guns is clean and oiled
  • make sure you are using the right kind of nails
  • some perfer the ones connected my wire and some the ones connected my paper.
Not knowing what kind of gun you have that is the best I can do..
Malibu 1976
  • 83 Answers
  • Posted on Sep 26, 2010
SOURCE: looking for piece that screws in the handle of a
Central Pneumatic (aka Harbor Freight), is usually very good for those replacement parts. On their website, to order replacement parts it says:
Please call our Customer Service Department at (800) 444-3353 Monday thru Friday, 6:00 am - 4:30 pm PST. Hope this helps... it might help to have the manual with an exploded view of the parts handy to describe what you need.
Anonymous
  • 43501 Answers
  • Posted on Mar 06, 2011
SOURCE: my paslode angled finishing gun keeps jamming
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
1helpful
2answers
Single piece trigger and firing pin.
Yes, but it takes an experienced gunsmith/welder to know what welding rod to use, how to finish the firing pin to the correct dimensions and MOST importantly, how to heat treat the pin area to make it durable and last.. and not break!!
2answers
Never shot this size of hand gun before, have shot a ruger 357 mag 150 grain bullet. what bullet would you recommend to shot with?
Shoot it with .38 special cartridges to practice trigger control and function drills (less recoil). Save your .357 for hunting, self protection, and familiarization fire. The weight of the bullet is not overly important, construction is. hollow points for self defense and hunting medium game. Rule of thumb? Light weight and fast for humans, heavy weight and slower for medium game.
Dec 18, 2013 • Optics
I did a complete rebuilt kit and replaced the o rings and trigger vavle. There is no more air leaks but the gun isn't firing at all. What should I do now?
Remove the nails and remove the trigger to expose the firing pin on the trigger valve. Connect air and very quickly depress the firing pin all the way in with finger. If the gun fires, adjust the safety foot to depress the firing pin all the way in. If the gun does not fire, most likely the problem is that two orings that make contact with the cylinder spacer (white plastic piece around the cyl.) and the cylinder are leaking between the chambers. Check for snug fit as spacer could be worn. Pull out the cylinger and remove all the lower parts so that you can slide the cylinder in and out of the spacer. The cylinder should fit snuggly into spacer and have some resistance. Try with one oring installed on cylinder , then both as one or both may not be snug enough. If it fits loose, install a couple of winds of Teflon tape into oring groove then reinstall the oring. Again check for snug fit (or replace the spacer if surface is scratched). Reinstall using white grease and retest. Good luck.
3answers
What is a blowback airsoft gun?
Blowback Airsoft Guns are Airsoft weapons that seem much the same as true firearms, since genuine firearms, well some, are secured in a Blowback layer of paint or something to that effect.
The entire slide on the gun with re-cock itself consequently after every shot then generally in the wake of shooting the complete cut after the last shot the slide stays open. The main issue with these airsoft guns is they will consume through your gas. CO2 or green gas both can have blowback.
1helpful
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
1helpful
Dewalt D51822 nail gun does not fire nail. When trigger is pulled air can be felt coming from the trigger area. I have replaced the trigger valve assembly and it had no effect. Gun is about 3 years old...
There are 4 orings that cause this problem. Two are in the trigger valve installed on the firing pin. The firing pin can be seen just under the trigger, however if you replaced the valve, you could assume no problems with the trigger valve. I would take apart the old trigger valve and examine the orings on the pin. The pin should fit snugly in the trigger valve cap and also in the valve. If the orings look good and it does fit snugly, most likely valve is still good. The other two orings to suspect are installed on the cylinder inside the nailer and make contact with the bulkhead (white plastic piece that seals the cylinder note parts reference 55, 74, 11 on the parts list). For parts list and to order parts go to www.toolpartsdirect.com Good luck with your repair.
Every time I load my easy shot 5650 stapler they fall out the end they are supposed to shoot out...why is that ??
The way you load this staple gun is: (1) turn it upside down (2) press the unlock tabs on the rear end of the loading slide trey and pull it back (3) droup a row of staples into the slot w with the pointed end facing up, while keeping the gun upside down, push the spring loaded slide tray forward until the locking tabe engauge. (4) turn the gun rightside up (away from you), and fire it. the stape should come out normally, the rest should not fall out.
Framing a 2x6 wall
does the nose piece go back as far when you actually use the gun as when you pulled it back? I had the same problem with a different model, The nose piece acts as a safety to stop the gun firing when not up against whatever you are nailing. If it a similar design to mine (and most are) if you follow the nose piece up the gun somewhere along that will be some sort of bend in the metal to form the safety. it sounds like this needs to be bent a little more so it actuates the safety off valve/switch. Be careful though that safety is there for a reason, dont bend it too far and make the safety too sensitive. Hope this helps
Pete
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
