SOURCE: lug size and pattern for 5 lug wheel adapter spacer
http://www.1010tires.com/tiresizecalculator.asp
I hope this will help you. Good luck
SOURCE: IBM personal wheel writer 2, wrong letter is typed
Try code "L" it will get you out or the language mode
DickyO
SOURCE: IBM Wheel Writer 6 font help
Hi:
There is no manual way to change the pitch on any IBM Wheelwriter. If you want a different pitch you need to change the printwheel.
Andrew
SOURCE: IBM wheel writer 5
If it is printing just the tops the platen may not be fully seated in the side frames, press down firmly on both ends of the platen.
If it is just printing poorly the print solenoid cap is cracked or the ribbon may not be feeding properly.
DickyO
