Cars & Trucks Logo
Anonymous Posted on Feb 13, 2018
01 Xterra dead battery. Tried jump, when I turn key alarm goes off blocks starting. Fobs wont disable/unlock. Only gets power to anti-theft. *Alarm doesnt go off opening door only turning key to start
I have tried: 1 Trickle charged battery to get power to try to disarm w key fobs. 2 Disconnected battery, waiting then reconnecting to try to reset. 3 Pushed valet button for alarm bypass/reset by kick plate fuses. 4 Tried unlocking doors manually with key to reset system. 5 I tried connecting OBD Scanner to get code but I can't get power to it and alarm goes off. 6 Removed anti-theft fuse from box under hood to try to bypass. I'm at a total loss here. Please help!
Vernon Taylor
Level 3:
  • Cars & Trucks Master 7,446 Answers
  • Posted on Feb 13, 2018
 Vernon Taylor
Level 3:
Answers
7446
Questions
0
Helped
1957563
Points
26207
You could try disconnecting battery, leaving overnight and then inserting ignition key and switching on before reconnecting the battery.
It has sometimes worked for me but in reality it seems you probably have an alarm immobiliser fault you need specialist help with.
Testimonial: "Yea, I tried leaving it disconnected overnight and reconnecting with key in position 2. Didnt work, but thank you"
5 Related Answers
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Dec 03, 2009
SOURCE: 2006 kia spectra. The power door locks
security ----encrypted software dealer only
Anonymous
  • Posted on Feb 24, 2010
SOURCE: alarm and door lock malfunction 1996 Camaro z28 LT1
Hey just wondering if you ever go this problem fixed. I am having the exact same issue. Thanks
wfservices
Wayne Fellows
  • 262 Answers
  • Posted on Mar 11, 2010
SOURCE: 1996 Explorer anti-theft system won't disable
Try re-setting the computer...Disconnect the negative terminal of the battery and leave off for 5-10 minutes. This will allow the computer to reset. The charger may have interupted the signal or something.
Don
  • 87 Answers
  • Posted on Dec 27, 2010
SOURCE: I have a 95 VW Jetta III that I just purchased.
Insert the key into the door lock on the driver side and move it to the unlock position two times quickly. That should turn off the alarm.
Anonymous
  • Posted on Feb 22, 2011
SOURCE: pt cruiser disable alarm
battery of car is zapped of energy...not sure if alarm system to blame, after driving it for a few minutes..clock and radio display lights turn off, horn can barely be heard...sometimes, motor shuts down completely. have had to put in 2 new batteries in just a matter of 2 months?...any idea what this may be?
How to reinstall key ignition in 2003 KIA Sedona
2001 Nissan Xterra no longer have key fob! Want to know if I can pull fuse out of anti theft alarm and lock n unlock manually with no issues?
no fuse for anti theft ---lock and unlock manually only thing is if to slow to put key in ignition alarm will go off but goes off/ resets when turn key order a new fob online their cheap
My 91 honda accord wont start after replacing the battery and starter all other functions work
Anti-theft needs pairing, transponder in the key to the receiver in the steering column.
How to Reset My Honda Accord Anti-Theft After Changing a Battery
  1. Insert the ignition key in the Accord's driver-side door lock.
  2. Turn the key to the unlock position.
  3. Turn the key to the lock position.
  4. Turn the key back to the unlock position. The alarm should now be disabled.
How to Reset My Honda Accord Anti-Theft After Changing a ...
https://itstillruns.com > reset-antitheft-after-changing-batte...
How do you reset the anti-lock system in a 2015 ford explorer
Press the unlock button on your vehicle's key fob to deactivate the alarm.
If you've misplaced your remote for the car, use the PATS programmed key to unlock the driver's side door.
Then, put the key in the ignition and turn the key to the "on" position. The vehicle's battery should be on, but the engine shouldn't be running.
Locate the override button on the alarm box, beneath the driver's side of the dashboard.
Press the button and hold it in until the alarm beeps one time. The LED light for the alarm should stop blinking, indicating the anti-theft system is disabled.
To reset the vehicle's alarm, put the PATS programmed key in the ignition and turn the key to the "on" position. Press the override button.
When the alarm resets, it chirps two times and the LED light begins blinking.
2answers
Anti theft wont let me start car
The problem may not be with anti-theft but with a bad fuel pump,cam/crank sensor etc. Also, you may try unlocking the drivers door with the key. On most cars that is the standard method for disabling the security system.
2answers
My battery went dead, and now that i try to jump start the vehicle, the alarm goes off and will not turn off. I cannot start the car at all
If this is an after market alarm, an alarm that was installed by someone other than a dealer there will be an in-line fuse under hood on the main power wire leading to the alarm horn. Usually along the firewall. Remove this fuse and you should be able to start the vehicle. The problem you are experiencing is the anti theft or ignition kill switch being activated because the alarm is detecting the lose of power as a Surge and triggering the anti theft circuit.
Car alarm won't turn off after recharge of battery
Try closing all the doors and locking and unlocking the doors with the remote,that should take it out of anti theft mode.
1helpful
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
8helpful
3answers
Isuzu Trooper anti-theft alarm
i put a new stereo in my 1998 isuzu trooper now the anti theft wont let car start what do i do
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
