Question about Frigidaire Kitchen Ranges
The oven for our Frigidaire FGGF3042KF gas range will heat up but not maintain temperature. We have to cancel and re-start the oven.
    Top Expert:
  • Frigidaire Master
  • 29,139 Answers
You need a new thermostat. Call an engineer, it is gas, you can't fix yourself.
Posted on Feb 13, 2018
SOURCE:
  • 184 Answers
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
  • 111 Answers
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
  • 188 Answers
SOURCE: Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Posted on Apr 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 22, 2010
Bake element wont cycle the temperature
PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204143.pdf
Note: The oven function will not work if the time of day clock is not set. ... The ovencan be programmed for any temperature from 170°F to 550°F (77°C to ... Can be used with BAKE TIME to program a delayed bake cycle. Timer Pad- Used to.
[PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204125.pdf
cycle. Bake Time- Use to enter the length of the baking time. Timer ON/. OFF- Use.... It does not disable the clock, Kitchen Timer or the interior oven lights. TIMED. DOOR .... The Preheat feature will bring the oven up to temperature and.
Gas Oven Repair Manual - Chapter 6 ' Gas Ovens Manuals
www.appliancerepair.net/oven-repair-6.html
If it does not ignite, you certainly do not want the gas valve to stay open. ... these sensor bulbs do not cycle the burner on and off to maintain oven temperature.
How To Fix An Oven Door That Won't Open After A Self ...
Jan 28, 2016 | Frigidaire Kitchen Ranges
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
My Tappan gas oven will heat up to temperature when first started but will not maintain temperature after that. The burner will not re-ignite. If I lower the temperature to the off position then put back...
thermo couple may be defective. Disconnect oven, look inside oven it will be a 2-4 inch tube looking brass type metal. use ohm meter check continuity if non then most likely its defective. other then that it may be the control board.
Sep 11, 2017 | Tappan Kitchen Range
Top burners on Frigidaire gas stove come on but the oven will not.Whats the problem?
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 30, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Frigidaire oven wont ignite
Jan 29, 2010 | Frigidaire FGF378AC Gas Kitchen Range
Oven temperature control intermittent
gas oven?? i would replacethe bake ignitor, the most common issue with unit not holding temp.
Nov 22, 2008 | Kitchen Ranges
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
