You might try these folks. I've bought parts from them.
https://www.ereplacementparts.com/drill-press-parts-c-18715_18731_18747.html
SOURCE: ryobi spare parts
Unless you have the part in hand, which you could take to a specialized machinery or spring supplier to see if they could match it up, the only other way to get the correct part is to contact ryobi direct and talk to their parts department. They will be able to tell you the part number, and if available, send you one out direct from their warehouses.
Good Luck!
Testimonial: "Thank you very much for taking time to help! I have phoned Bunnings who I think are now the only suppliers of Ryobi in AU who are sending a spare. "
SOURCE: Where do I get parts for a clarke drill press model bt1029?
the part number I found is BT1029-0038 for the quill spring and you can contact them at 1-800-227-9603 and see about ordering the part. If I have helped you would you please rate this response accordingly and thank you.
SOURCE: Need a take up spring for old craftsman drill
Hello. Craftsman only stocks parts for their tools for a ten year period. If you want to look and see just go to searsparts.com.
Your best bet may be to take your worn spring to a hardware store and match it up with one that they have in stock.
SOURCE: I have a Mastercraft drill
Hello Jo Ray. The chuck is friction fit. To reinstall it you may need an assistant. Put the chuck on the spindle, have your assistant hold it while you hit it using a block of wood against the chuck and a hammer. A couple of good blows and the chuck will be installed. Regarding the spring, go to this link and select the canadian tire store closest to you to get the part. http://www.canadiantire.ca/AST/NavigationAssortments/WebStore/Navigation/FooterNavigation/BusinessLinks/Section1/CustomerService.jsp
