GE JTP20 Electric Single Oven Logo
Posted on Jul 30, 2009
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a 326B1230P001 GE Double oven that displays “F7” and beeps…..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself….what is wrong with the brain on this…?
Bob
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 01, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
17698
Points
9
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at [email protected] for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
I have GE Oven/Stove combo Model #326B1230P001. I get an error message F7 & Flashing E7 code and it beeps. How to fix this?
this error for GE means that your touch control panel has shorted and the entire touch control panel would need to be ordered and replaced if resetting the circuit breaker won't reset the issue.
Oct 13, 2018 • GE Ovens
1helpful
The oven is randomly beeping and the display is reading f7
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic oven control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
My oven beeps and show error code F7 on the panel. Help!!!
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Oven beeps and shows F7.
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
2answers
Our JTP15 beeps and displays F7 is there a reset for it?
Yes, you will need to press the stop/cancel button, this will clear the error code and the display.
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
3helpful
2answers
F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
F7 on the display with constant beeping
F7 for GE is either a stuck button on keypad or bad EOC. Try shutting breaker off 20-30mins and see if it resets itself.
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
