I have a new tv smart model xbr-43x800d trying to run sound through my onkyo amp model tx-sv7m. How do I connect new to old
SOURCE: Onkyo TX SV7M Knocked out by Power Surge
Try pulling the plug out of the wall for 5 min or more,give the unit a chance to reset.Hopefully you didn't get a power surge that might have blown the protection circuits.
SOURCE: Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
SOURCE: How do I connect my Lenovo X200 Tablet to my new
Couple things to be aware of:
1. The X200 is not available with a Blu-Ray drive. So, your HD content will need to come from somewhere else, such as downloading from iTunes. Alternatively, you can purchase an external Blu-Ray drive. (it may be cheaper / easier to buy a dedicated Blu-Ray player if that's the route you want to go).
2. The X200 only has analog audio output. The only surround you'll be able to receive is Dolby Pro-Logic, provided your source material has it encoded that way. You can connect your laptop to the receiver via a 1/8" to RCA adapter, available at virtually any electronics retailer. (Buy the cheapest one you can find) Connect the 1/8" plug to your headphone jack on the laptop, and the white and red RCA connections to any available input on the back of your receiver. (such as CD, AUX, DVD, etc.) Select that input on the front of your receiver and you'll hear the output of your laptop. Enable surround sound processing (pro-logic) on your receiver. Check the manual for instructions on how to do that.
3. Purchase a VGA cable (I recommend monoprice.com ). I suggest staying under 15' for optimal quality. Connect one end to your laptop, and the other to the PC-in on the back of your TV. Select that input using your TV's remote. (On my Sony, I press Menu, External Inputs, then PC)
4. Set up your laptop to use the external monitor. I suggest leaving your laptop off till you plug in the VGA cable. If upon booting your laptop is outputting to the TV display, usually a key combination such as Shift-F7 will enable it.
Alternatively, your TV has an 1/8" audio input jack that goes along with the PC input. If you've connected the audio out of the TV to your receiver already, the audio from your laptop can pass through the TV to the receiver. 1/8" cables can also be purchased from Monoprice.com.
Let me know if that helps!
SOURCE: connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
SOURCE: How do I connect my bose 901 active equalizer to a onkyo tx-sr506
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
