SOURCE: JANOME dIGITIZER 10000 - "JANOME.EXE has stopped working"
Digitizer 10000 v2.21 might run in compatibility mode on Vista, but there's no gaurantees. Even the latest digitising suite Digitiser Pro/MB is experiencing problems running in Vista 32 and as yet has no real fix (driver) for Vista 64.
SOURCE: Attempting to find Janome customizer 10000 plus software
Simply contact your nearest Janome dealer, or the Head office in your country and they will be pleased to assist and outline the options available.
SOURCE: Janome Customizer 10000
There are different programs for 350E. I think, you was buy program different.
SOURCE: Janome MC 10000 with Easy Transfer using jef files
Try saving your Monogram Wizard design to your computer. Then open Easy Edit and Import the design using the drop down menu under File. Manipulate the design and then send it to the machine using Write designs. You will have to make sure the design is going to fit in the hoop correctly before you save it to .sew in the Monogram Wizard program. On the save screen... near the bottom there is a box about turning the design sideways and this is often the problem. Will be glad to talk more. [email protected]
