SOURCE: Only half the grill is working
There are two elements on the grill, left and right. One has failed and needs replacing. Can't tell you how, we haven't got that far, but we bought replacements from e-Bay £9.99 each + £2.50 P+P. Official suppliers charge £21+.
Beth
SOURCE: rangemaster classic 90
Regardless of the clock running, if the timer is not set to zero and off, the oven will not function. See my instructions on using the timer (http://www.fixya.com/support/t1416237-timer_instructions_rangemaster_toledo) I hope that this is your problem and it will show you how to get the oven going again.
SOURCE: t took the large oven door off my rangemaster
You should be able to lift the door, align the hinges into the slots.Then lower the door and allow the notched area of the hinge to fall into place. This may take a couple of tries to accomplish.
Testimonial: "thank you so much i'll try that."
SOURCE: Grill Element Blown Rangemaster Classic 110
I have the same problem. The installation and service guide details how to change the grill element but does anyone know what the part number is for the grill element?
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
