Paula Deen 8 qt Ceramic Nonstick Pressure Cooker One Button Release...
You could purchase new or used identical model on the internet.
SOURCE: i HAVE AN ULTREX 8QT. SLOW COOKER 9QT, ROASTER.
Innova, Inc.
P 800-767-5160
F 913-541-8561
[email protected]
Ultrex Slowster 8 qt slow cooker 9 qt roaster Model 08393
SOURCE: the nonstick coating is peeling
That has happened to me many times. You would think with the prices of kitchen cook ware that would last longer. I have turned a once nice pan that cost lots of bucks in to a camping pan. Sad ,but true but if you can find a can of spray on tephlon you can re coat the dish.Look in specialty hardware stores . Or you may be able to buy a can on line. The stuff is out there. good luck DFD please rate me TK U
SOURCE: Steam coming out of floating valve on handle.
No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
SOURCE: Paula Deen toaster egg poacher caught on fire
The same thing happened to me today and I've been searching the internet for other complaints. It happened exactly as you said, I heard a buzzing noise and went to see what it was and it was the toaster- smoke started to come out from the top. Please report your experience to the CPSC! http://www.cpsc.gov/index.html This thing needs to be recalled!
