Grinders Logo
Julie Stenstrom Posted on Feb 10, 2018
I need a Manual for Napa 1/4 die grinder - Grinders
  • Terry
    Terry Feb 10, 2018
    Hi Julie Stenstrom, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Is there a Napa model number?
    https://www.manualslib.com/n/napa+1+4+di...
    Many free Napa manuals at the web site above, but not sure which model manual you need.
Kim Baker
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 22 Answers
  • Posted on Jun 09, 2018
Kim Baker
Contributor
Level 1:
Welcome Back:
Answers
22
Questions
0
Helped
13566
Points
75
Jet 577102 is a bench grinder with 1HP motor. It has got guards on the grinding wheel. Dust vents and guard makes the grinder makes it an efficient grinder. 115 Volt is needed to run this high performance grinder.
Anyone know how I change the cutting disc please? I know this sounds really basic but I can't jam it as I turn the key tool.
here is a generic image of common die grinders. I imagine your's is the same. Now you need to "Jam the shank with the tool numbered
37 above. Its the slotted wrench. Once its properly secured you should be able to use a flat head screwdriver to loosen the retaining screw.
The worm gear broke
Time to buy a new air grinder!!
1helpful
Cannot figure how to get the point onto the die grinder.
Here is a link with illustrations on installing grinder points. Scroll about 1/4 of the way down and you'll see two links for "Operators Manual" Click the one that matches your model.
http://www.milwaukeetool.com/PartsAndService/DownloadManuals/All.aspx?ProductId=5192
Hope this helps you out.
I can't find a 1'4" collet for a Milwaukee DG14-50-Q die grinder. The removable collet chuck came with 6mm & 8mm collets. The collet Id No is 48-66 0965 but is no longer made. Does anyone know of an...
The 48-66-0970 has ribs on the outside and fits the old 5195 die grinder. If this is accurate let me know and I will try further to locate it for you. Where are you located as this might help
I need to find a repair manual for a dw887 die grinder
You can get a parts schematic and instruction manual at Dewaltservicenet.com just by typing in your model and then you click on the one with your type number. As far as a repair manual they don't have one Let me know if you need any more help
Safety Machanism Question
Most die grinder throttles feature a spring-loaded "kickstand" mechanism between the throttle lever and the body of the grinder, which prevents the throttle from opening (being pressed down towards the body of the grinder) without operator intervention. This prevents the die grinder from accidentally activating.
Motor Speed Question
The RPM rating of the die grinder is the deciding factor in the toolā€™s usage. A die grinder with a lower RPM is best used for fine grinding and finishing work. Speeds lower than 10,000 RPM are best for this function. A die grinder with an RPM between 10,000 and 20,000 is great for creating rough finishes and minor buffing jobs. If the die grinder will be used to remove metal burrs or to cut metal, it must have an RPM rating of over 20,000 and a no-load speed of at least 30,000 depending on the RPM rating.
2answers
Die Grinder usage
these tools are handy for any finishing or grinder that needs to be done in a small spot.
Top Grinders Experts
Oliver Street
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Grinder Expert? Answer questions, earn points and help others
