Question about HTC Computers & Internet
HTC Media link. Need to reset password or find original password. HT C 10 doesn't have 3 finger gesture. Want to use app to access media link.
4 Suggested Answers
SOURCE:
  • 556 Answers
SOURCE: PS3 access problems to media server on wrt350n
I believe a simple solution to this beings with assigning a static IP address to the PS3
IF your router is 192.168.1.1 and
your subnet mask is 255.255.255.0
and your DHCP range is 192.168.1.100 for
50 licenses to 192.168.149
The address your PS3 between 192.168.1.2 and 192.168.1.99
Configure you PS3
IP address192.168.1.3
Subnet Mask 255.255.255.0
Default Gateway 192.168.1.1
DNS Address 192.168.1.1
(for the above DNS address to work you must have loaded the ISP assigned IP addresses into the router which you probably have alrready done.
Let me know if this does not work. I will respond to messages here until we resolve the issue.
Then on you router your DMZ address should be set to 192.168.1.3 (your PS3's IP Address)
Posted on Dec 24, 2007
SOURCE: Lack of Equalizer in the media player of HTC S710
The media player of my HTC S710 does not have equalizer options.Please suggest me some music player softwares for this phone, and the links to download the softwares.
Posted on Nov 17, 2008
sa3yo2000
SOURCE: forgot the password to my HTC media link wifi. Need to reset it. How do I do that?
just press the power button for about 15 sec, until it's reboot itself
Posted on Oct 10, 2012
Keeps telling me the ID and password do not match
If things really go south on your FireTV then you need to perform a hard reset, returning it into factory default mode. This will leave your FireTV just as if you bought it.All personal configuration, installed apps, games, passwords, etc. gone! but then, a hard reset will almost guarantee to recover into life your fireTV from non-working state.
You need to press RIGHT and BACK buttons for 10 seconds to initiate the Factory default reset.
Then you will have the original default username and password, which shold get you in to set it back up.
Oct 01, 2016 | Amazon Fire TV Stick
Tip
Palm Pre Plus tips and tricks
1. Soft Reset Hold the power button and cycle the ringer button on/off three times.
"Orange button" "Sym" and letter "R". It's like a Ctrl Alt Del for the Pre.
Another way is go into "Device Info" --> "Reset Options" At this point you have three choices:
a. Soft Reset -restarts it
b. Partial Erases -erases all installed apps and their data but not personal files stored in Mass USB drive mode.
c. Full Erease -Everything Partial erase does and personal files stored on USB partition.
3. Save Battery Life
Pre_with_battery
- Log out of AIM (There is some problem with AIM draining battery power that Palm is currently fixing. And plus, who really uses AIM these days?)
- Change your email settings. Note: each email account can be set-up in a different way.
Top on the upper left corner of the screen in the email program.
Open the Preferences menu.
Set frequently used accounts to check every 15 minutes.
Set rarely used accounts to Push.
- Turn on WiFi. (It's weird, but the Palm Pre has better battery life with WiFi than with 3G.)
4. Gestures
Tap
Swipe A horizontal gesture on the touchscreen or the gesture area. The most common swipe is "back", which is a swipe from the center of the phone to the left in the gesture area.
Drag Drag upward from the gesture area onto the touch screen to bring up the Quick Launch menu when you are in an application.
Flick
Scroll Speed sensitive. Tap or drag the screen while scrolling to stop.
Zoom Double tap on an image or area, or use two fingers in a pinch-like fashion.
5. Turn On Advanced Gestures
Go to "Screen & Lock" app
Turn on "Advanced gestures" setting
The advanced gestures allow you to scroll in between apps while they are open in fullscreen mode. Simply swipe from the far right the far left, or from the far left to the far right, in the gesture area to move between apps without going to the Card View first. The back gesture still goes from right to left in the gesture area, but it takes a shorter swipe from right to left (halfway).
6. Tap the Battery
Pre_popup
Tap the battery icon to see an exact percentage of remaining battery life, the date, WiFi options, Bluetooth settings, and Airplane Mode settings.
7. Uncapitalize a Letter
When typing, the Pre autocapitalizes letters where appropriate (beginning of a sentence, "I", etc...). To undo this, simply press backspace once. Rather than deleting the letter, it will change it to lower case. Pressing backspace again, obviously, will delete the letter.
8. Pre Recovery Tool Leak
This Pre hack applies mainly to the super tech-savy guys out there, particularly the developers. The "WebOS Reset Doctor" has leaked out (including the 195 MB webOS root). This means that you can now view the Pre's "hidden" code, which means you (or some really skilled developers somewhere) can find and tweek some hidden Pre features.
9. Sync the Palm Pre with iTunes
Simply connect the Palm Pre to your Mac or PC, select "Media Sync", and iTunes will auto-launch. You can then choose which DRM-free media files to transfer.
10. Use your Pre as a Mass Storage Drive
Simply connect your Pre to your Mac or PC with a USB cable, and the Pre will appear as a drive on your computer desktop. Drag and drop files into the Pre, or drag files from your Pre to the computer.
11. Solve Post-Shut Freeze
Pre_battery
Numerous people have reported that when you close the screen too hard, the phone becomes black yet backlit, and the only way out is to reboot. Turns out there is a problem with battery, because it becomes loose when you slide the screen down hard. Simply put a piece of paper on the top part of the battery between the battery and the phone.
12. Konami Code
Konami
This one is funny. To access the "secret" Palm Pre dev mode, simply type the famous Konami cheat code right from the launcher screen of your Pre. The code is "upupdowndownleftrightleftrightbastart". This opens something called "Developer Mode Enabler". This was discovered due to the leaked ROM (number 9 on this list). This allows you to connect the Pre to a computer running Palm's Mojo SDK for webOS, which allows you to do some dev stuff.
on Mar 13, 2011 | Cell Phones
How do i get my HTC Desire500 to configure with HTC media link HD
Probably the Desire500 is not compatible with the HTC Media Link HD.
Dec 06, 2014 | HTC Cell Phones
How do I get back a full screen instead of having 2 different screen open
Try with enabled gestures in general settings:
In apps where you can navigate from side to side, such as Photos or iBooks, you need to use the swipe.Using one finger, lightly run your finger across the screen from one side to the other and you can navigate from page to page in one simple motion. get-back-full-screen-instead-having-2-u3wnnnxjlb3ct0ebur4t0xqn-1-0.jpg
How to use Gestures on iPad iPhone iOS
Sep 28, 2014 | Apple iPad Tablets & eReaders
I need to change my pass word
When signing in, put your name in but in the password box click the ''forgot password'' then it will ask you for, 1= a hint of your password 2= your email address where it will send you a link to reset your password. This is also recommended to do this every 6-8 weeks to stop your anyone getting into your facebook account. 3= The other option is answer the security question you set for your account when setting it up. Hope this works and you get sorted,, good luck.
May 07, 2014 | Facebook Apps
How to turn off Htc Media link
Settings > Display, gesures & buttons > Gestures > uncheck gestures smile.gif
This will disable this three-finger-gesture.
Sep 13, 2013 | Computers & Internet
Forgot the password to my HTC media link wifi. Need to reset it. How do I do that?
Jun 20, 2012 | HTC Media Link HD
Unlocked htc inspire need apn and mms
For the HTC Inspire on Family Mobile, you'll need to create two APNs.
1. hit menu -> settings
2. hit "Wireless and Networks"
3. hit Access Point Names.
4. hit menu -> Reset to Default
5. hit menu -> New APN
Enter the following settings exactly. They are case sensitive. Any setting I do not list here should be left alone. Please note that in the "APN Type" setting, there are no spaces after the commas.
APN: Phone
APN Type: default,admin,hipri
6. Hit menu -> Save
7. Hit menu -> New APN
APN: web.omwtoday.com
Proxy: 216.155.175.188
Port: 8080
MMSC: http://wirelessfour.mmsmvno.com/mms/wapenc
MMS Proxy: 216.155.175.188
MMS Port: 8080
APN Type: mms,supl
8. Hit menu -> Save
9. Make sure the first APN - "MEdia Net" - is selected by the radio button on the right side.
When you complete step 9, your data connection should drop and then come back after a few seconds.
10. Reboot your phone by holding the power button for 3 seconds and choosing "Restart Phone."
Done!
Mar 16, 2012 | HTC Inspire 4G Smartphone
Android.process.media stopped working
Best practice would be to revise recently installed media apps-uninstall as needed-logcat log would be advisable.
If it is first install and start of ROM, problem could be to flashing of ROM (wipe/factory reset, first backup by nandroid od titanium backup-note that titanium doesn't backup all data).
Jul 26, 2011 | Android Apps
Magnified screen on my iphone
STUPID SOLUTIONNNNNNNNNNNNNNNNNNNNNN
Doesn't work, what an idiot. Just tap twice with your 3 fingers & your zoomed screen'll get back 2 normal
Jul 11, 2009 | Apple iPhone Smartphone
Computers & Internet Logo
262 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
