Televison & Video Logo
Ralph Howell Posted on Feb 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio e500ib1 50"smart tv power on light then that goes out. has 5volt stand by only, there are voltage that come up but fade out. screen is black no sound. was working great perfect picture,
Working fine then turned off now nothing ,power light and it fades out black screen no sound no back lights 5v on power supply only all other power fades awayen power light goes out.
Larry
Level 3:
  • Vizio Master 5,042 Answers
  • Posted on Feb 09, 2018
Larry
Vizio Master
Level 3:
Answers
5042
Questions
Helped
1239558
Points
18413
Do you have voltage (3.5V) on the PSON terminal when you push the start button on the TV...if you don't its the main board that has failed
Testimonial: "I have 3.5 volts and 5 volts nothing else."
  • Ralph  Howell
    Ralph Howell Feb 09, 2018
    do you advise buying a power supply board, the set is worth the $80.00, just trying to nail down the correct board to buy.
  • Larry Feb 09, 2018
    I would think it should be worth that much
5 Related Answers
A
Anonymous
  • Posted on Mar 25, 2008
SOURCE: Plasma no picture, fades to black from startup logo
UPDATE:
I finally isolated the problem, the problem has to do with the Y SUSTAINER BOARD not receiving enough/necessary voltage when turned on, while initially thinking it was just the yboard was the problem, i replaced the Y sus board with no success, with only further diagnosis, i discovered the board voltages coming from the powersupply, there are 5 voltages that relate to the Y sustainer board, VA, VSC, VS, VE, VSET. they all supply a certain voltages that all have to be supply the correct voltage in order for the y sustainer board to be working, well guess what, the VA line, which for my set needs 70volts, which upon startup quickly drops from 75volts to a jumpy 8.5-9.5 volts, which of course is nowhere near the 70 volts needed, so this quick drop in voltage is directly related to the screen fade upon startup, i found the problem now the real problem is finding a replacement power supply. hope this helps anyone with similar issues.
Anonymous
  • 155 Answers
  • Posted on Oct 26, 2008
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
B52Tony
Tony Nguyen
  • 96 Answers
  • Posted on Jun 18, 2009
SOURCE: No Screen or sound
there are two possibilities to this problem. First and cheapest way is to replace the main board. Second, replace the inverter board. This is the boards that are mounted vertically on both sides of the TV.
MLFnet
Marvin Fife
  • 328 Answers
  • Posted on Oct 26, 2009
SOURCE: Vizio plasma. screen went black, and the power light went out.
Sounds like the power suply went. I don't know that model off the top of my head, but you might find a replacement here http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=EU&Category_Code=PLA
-=/ Daft Tech /=-
Anonymous
  • Posted on Nov 02, 2009
SOURCE: Vizio 50 inch plasma tv has no picture and no
check the Y-sus and Z-sus board
1helpful
2answers
1helpful
Vizio P602ui-B3 won't power up. during viewing 1/2 of screen went awsy then other half froze. shut down wont come back on. Power light comes on - then fades. Then power light flashes 16 times. is that...
More than likely that is a main board problem. Check to see if you have stand by voltage. if you have stand by its the main board if you don't then its the power supply.if you change the main board out and it don't work then your Tcon board is bad too. thats the problem 99%
of the time when you have half screen.
2answers
Vizio m55-c2 55-inch 4k ultra hd smart led tv fixing won't turn on
Your done, replace the TV before you bury yourself in parts cost and labor.
I have a Vizio E421VA LCD HDTV and am getting a black screen. The power light comes on, but am still getting a black screen. Does anyone have the same problem and/or solution?
To determine if the backlight driver or the T-Con board is the problem, di this. With the TV on shine a flashlight on the screen. Look for a faint picture. If you can see one then the backlight control board is bad. If you see no movement or any picture at all, the T-Con board is bad. You can get the parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
2helpful
3answers
I have a Vizio 37 inch lcd tv. It works fine from
Hi msyaros
In order to have data`s specific to model , i would need the model# written on the back of the tv set.
Be waiting for your reply
2answers
Vizio glv47 powers up no then no picture
We have the same problem and purchased a power supply to see if it would fix the problem. It didn't. We are now in the process of buying the main logic board and we will let you know if this fixes the problem. It seems like it is in sleep mode but doing the steps to get the tv out of sleep mode does not work.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
