Question about Frigidaire Kitchen Ranges
Frigidaire FEF352FSA Oven interior light will not turn off. Have tried flipping the lighting switch on top of stove (switch to turn interior light on/off) on and off.
    New Friend:
  • 20 Answers
Might be that the switch activated when you open the oven door is malfunctioning for some reason.
Posted on Feb 09, 2018
Testimonial: "The light just randomly turned on and has stayed on after using a burner on stove top, haven't/hadn't used the actual oven part for a few days. Any solutions to why or how it would be malfunctioning or how to fix?"
SOURCE:
aborcass
  • 2651 Answers
SOURCE: premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Posted on Oct 29, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
daddy1264
  • 76 Answers
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Posted on Jan 01, 2009
SOURCE: frigidaire electric range oven and top burners wont come on
It sounds like you only have one side of the 220v current coming into the range. I suggest checking the outlet feeding the range for proper power. The problem could actually be in your circuit breaker, only sending power via one of the conductors.
Posted on Mar 12, 2009
  • 222 Answers
SOURCE: Kenmore gas stove - oven won't ignite
hi gud day,do u think the gas is ok or every time u open is come out, or check ur control gas line valve maybe it close or authomaticaly close due to some laekage. chect it by smeling every turn on ur knob,but unplug the item b4 u do.
tnx gerbee
Posted on May 29, 2009
The power went out and when it came back on our stove is not working. No lights on the display. The stove is dead. Is there a way to reset the oven???
Did you trip a breaker. Try to flip the breaker switch that goes to the oven. You may have to flip all the switches and flip them back on to get the correct breaker switch.
Jun 14, 2017 | Kitchen Ranges
Stove top stopped working but oven and warmer element work.
You have a defective breaker. Once you replace it the oven will get the correct voltage restored.
Aug 13, 2016 | Kitchen Ranges
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
When our family returned from out of town, we had no heat. I plugged in a small space heater close to the stove to help heat the kitchen. A bit later, I started to make toast and a breaker flipped. Flipped...
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Apr 30, 2017 | GE JBS55 Electric Kitchen Range
BURNER IGNITION WILL NOT TURN OFF. When turning stove top on, all 4 burner ignitions continue to stay on. They will not stop clicking. Only when I unplug the oven will they turn off. It is a Frigidaire...
One of the switches is stuck,causing circuit to 'think' that you're trying to light a burner. Give each control knob a good 'tap' with the back of a screw driver.If that doesn't free it up, we will have to find the stuck
switch
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 25, 2009 | Frigidaire FGB24S5A Gas Single Oven
Electric stove top and oven
hi
if neither the cooktop nor the oven works check your voltage. Is there 240 volts to the unit. Flip the breaker off and back on. If that doesn't work, with the unit unplugged, remove the cover where the stove cord is connected and check the connections
Good Luck!!!
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire stove
Sep 17, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
