Your compressor is hot... unplg now and vacuum ..actually better to blow out debri.. but clean under fridge. Now!!!. Ok...pay one of your kids 10 bucks to do it they are more agile . Careful not to be banging the fan with vac hose.do that and youll be sorry as thats why the compressor is hot and cranky.
SOURCE: Braun Tassimo Type 3107
I found that most problems around the tassimo relate to the peircing mechanism being clean and properly in place (it moves sometimes when you open the lid), or that the "window" that reads the barcode needs to be kept clean. When i've gotten all lights blinking or going right to manual, I have found cleaning the window seems to fix the problem more often than not.
hope that helps
SOURCE: pump motor makes loud noise when pump comes on
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out. There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
SOURCE: will not pump Kenmore model 970-c45072-00, purchased in 2005
Pump blocked probably something stopping it, sock, coin etc
SOURCE: when running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
SOURCE: Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
