Hi Dick Lober, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Is this an online game? Is it a newspaper game?
Is the answer White, as in Red, White and BlueHi Dick Lober, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
Dear Casey; gonna need a little more info, is there anything on the gas tank, under the seat, on the side covers inside or out that tells you who made the bike? Is it a single cylinder, 2 cyl, V twin, etc?
Any idea of year? Even sometimes inspecting the headlight, tail light, some sleuth work may give you some more clues. Posting a picture would even help. Best of luck to you
Thats if you wantto give yourself a "hint, or "clue" in case you forget your password. say your password is "dog" as a hint, you would put "treat" so when you hear the hint, then you will be able to remember your password. :)
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
"Sam" Sam Spade is a fictional character who is the protagonist of Dashiell Hammett's novel The Maltese Falcon (1930) and the various films and adaptations based on it, as well as in three lesser known books by Hammett.
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix):
1. RCA (red/white/yellow round connectors)
Red=right audio sound
White=left audio sound
Yellow=video
connect to the slots that look like they want some.
2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video.
3. Component (red/green/blue)(red/white) two 'bundles'
red=red component of video
green=green component of video
blue=blue component of video
red=right audio
white=left audio
4. VGA + (red/white)
VGA=video (computer monitor cable)
red=right audio
white=left audio
5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****)
HDMI=audio and video
6. hugs and kisses
hugs=video
kisses=audio (both sides)
2003 Mitsubishi Galant Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Black
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
I dont have a clue what happened... The screen is blue and has a little red lock on the upper left hand side... remote only works to turn it on...no other buttons work. Help please!!!
Well if there is orange I would think you lost your green. My question is this point are all three tubes lit up. That would give me clue what direction to send you in.
Most common reason for this would be defective power supply, if it is less than 1 year old, may still be under warranty. If older then you can usually find replacement power supply $40+ at local computer store. Not to difficult to replace, average tech could swap it in less than 15 minutes. Can test it with one of these: http://www.antec.com/Detail.bok?no=429
