Question about Hotpoint Washing Machines
My hotpoint washer WMFUG942 has displayed error code F06 and has flooded my kitchen due to the water from my machine expelling through the kitchen sink during the cycle thanks
    New Friend:
    Problem Solver:
  • 19 Answers
Please check for rodent nest. For some reason bugs and small rodents love to nest in areas of resistance..actuators..rexepticles..plug ins..sounds dangerous for the newborns right? Thing is its that old nest that is your problem now. It degrades and chunks jam here and there then stuff stops working. Adverse weather forces creatures to seek temperary shelter especially if a birthing event is looming. So don't try to stop it as nature always wins..but inspect your appliance as soon as you notice a change in performance before that nest costs you a days wages.
Posted on Feb 09, 2018
SOURCE:
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
Posted on Feb 22, 2008
  • 9 Answers
SOURCE: water every where
These machines have a common fault. If yours has no visible filter, the filter is in the rubber waste tube, just below the drum.
Most faults on these machines are due to a blockage or build up of sludge and lime scale in this area.
This also affects the pressure switch, which is linked by a plastic tube to the same place! This will cause the machine to stick, and not spin, otr to spin with water in the drum causing vibration.
Firstly check the outlet hose and the plumbing where the outlet goes to for signs of sludge and lime. Unless you have very soft water or a water softener, there will be some! Usually lots!
Clean this out.
Disconnect the machine from the mains and the water supply and pull it into a clear area.
Put a thick cloth on the floor and gently lay the machine on its left hand side, looking from the rear,
Undo the small panel on the back and you will see the black rubber concertina hose, pressure chamber and pump, which are now all easily accessible from the rear and the botom of the machine.
Undo the circlips with a screwdriver and the special plastic clips with a pair of pliers by twisting each part in the opposite direction.
Take the whole hose off. You find a filter and a "ping pong ball" inside this.
Clean it all out as thoroughly as you can. At the same time clean out the plastic pressure chamber and the pump. you might need to use a proprietary limescale remover or vinegar to do this.
You will usually find a few buttons, plastic items, paper, couins and a load of sludge!
Put the whole lot back, The plastic clips slide together with a toothed grip.
The whole job should take about half an hour and the machine will be like new.
Posted on Feb 29, 2008
ginko
  • 19396 Answers
SOURCE: Error code E:13
I thin E13 is motor error, I will check.
Posted on Sep 03, 2008
jason0110
  • 66 Answers
SOURCE: error code h20
hi sounds like a faulty fill valve easy fix
Posted on Sep 21, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
Sep 23, 2014 | Maytag Washing Machines
Hotpoint aqualtis aqxxf149hpi is showing a error h20
Check tube to water pressure switch. The wall of the rubber tube on my machine had worn through due to friction. Taped it up to make sure this was the problem. No H2O code and machine working!
May 27, 2014 | Hotpoint Ultima WF860 Front Load Washer
I have fault code F06 on my Hotpoint WMf740 machine, what does this mean?
F6 error is apparently a motor fault. The
motor could be jammed, open circuit ,
burnt out. It may just be a broken wire
or connection come off. Check the motor.
Dec 13, 2010 | Hotpoint Aquarius WD640 Front Load...
Error code on washing machine wf640
have you checked you have turned on the water back on???? check but red and blue, or just blue it must be 90degree left or right.
Mar 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Machine not starting ...Programme Progress Display light flashing
This normaly indicates an error code. Could be the anti flood device activated due to water leaks etc. The anti flood device (polystireene float and micro switch at base of machiene) puts the washer on pump out mode and shuts off the inlet water. Dry the water at the floor of the washer and check and rectify any leaks.
Jan 21, 2010 | Dishwashers
Error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Dec 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code h20
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
62 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
