You can call it comforter. In some instances the whole duvet can be washed. Check the label on the duvet.
A duvet is a component of bedding that is also known as the comforter. It is usually made of down that has a coverlet like somewhat like a pillowcase that you can remove and wash.
We can also call duvet a comforter and it is basically a soft flat bag filled with feathers, wool, and synthetic. All duvets are protected with the removable cover called duvet cover.
The first thing that comes in our mind is the great comfort which is definitely mandatory for a sound sleep.
Duvet, commonly known as Comforter and it is basically a soft flat bag filled with feathers, wool, and synthetic. All duvets are protected with the removable cover called duvet cover. In some instances the whole duvet can be washed. Check the label on the duvet.
Duvet is also known as Comforter and it is basically a soft flat bag filled with feathers, wool, and synthetic. All duvets are protected with the removable cover called duvet cover. You can remove this cover to give an absolute new look to your bed. Feather used in duvet are either made up of duck or geese feathers.
A duvet is a bed comforter made usually of down that has a coverlet like somewhat like a pillowcase that you can remove and wash. In some instances the whole duvet can be washed. Check the label on the duvet.
