SOURCE: Can't connect DVD player
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
SOURCE: Protron PD-800 DVD player
On the remote control of the DVD player, just press the P-scan, reset or video SW button.. That would fix it... If you have screen kumping problem then please try this following steps... Press the setup Down arrow once Enter Down arrow 1 time Enter Up arrow 1 Enter Set up
SOURCE: connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
SOURCE: what is the comcast remote code for the supersonic
Download the user manual for your remote here
http://www.comcast.com/corporate/customers/customer_support/remotes.html
