SOURCE: 1997 toyota tacoma ignition clicking
what engine size and transmission, automatic or stick shift do you have in this truck?
SOURCE: GS 300 vibration or clicking noise behind instrument panel!!!
I would check the door lock relay first, beings you have issues with door locks.may or may not be related.
SOURCE: 2006 Jeep Wrangler won't start
First, make sure you can turn the engine by hand. If you can't then the starter can't turn it either. Have someone else turn the key and look for the source of the click...may be a relay. Go over the starting circuit with a volt meter. Check for power at the starter main terminal and then with the key turned to "start" check for power at the trigger terminal on the starter. Check battery voltage and check relay operation.
You have a neutral safety switch on the transmission if its an automatic and a clutch switch if it's a stick. Check them as well. Make sure battery grounding on fender and block are also clean and secure.
Testimonial: "Will try! Thanks!"
i would check battery connections and test battery. a battery can have a bad cell and run lights but not have enough amps to spin a stater. if everything on battery is good i would suspect a bad starter
SOURCE: How do I replace the driver side fender on my 2012 dodge journey?
remove fender you have to raise vechicle remove wheel. remove splash shield remove bolts holding fender through wheel opening.then you have open hood remove headlight housing remove fender bolts behind head light housing.
