SOURCE: i pulled the plug on my precor efx and now it wont
yes, we can help. 281-469-8506 www.nashsfitness.com
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
SOURCE: belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
SOURCE: I own a Precor EFX 5.33 the drive belt snapped so
You use the two bolts that hold the step up pulley in place. The step up pulley is the pulley assembly that is closes to the back of the unit. The step up pulley slides into two grooves in the frame, then there is a bolt on each side that run down the groove into the step up pulley. These bolts are the bolts that adjust the tension for the skinny belt. You may need to loosen the other belt first then tighten the skinny then retighten the belt you replaced.
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
