Engel sr65e-g3-wh
SOURCE: Engel Portable Fridge/Freezer Schematic Diagram and Spare Parts
i need a schematic diagram of a fridge
SOURCE: freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
SOURCE: need to connect the water line to the ice maker
Hi Joanna,
All you'll need is a 6' long piece of tubing. One that's got a 1/4" compression fitting on both ends. You can get one at a Home Depot or Lowe's (and you can see what I'm talking about here).
Install is a breeze. Just roll your fridge out enough so you can get behind it. Hook up one end of the tubing to the valve on the wall and the other end to the connector on the fridge (that should be near the bottom on the right side... but it could be on the left), tighten both connections really snug and turn the water on at the valve on the wall. <--- remember "righty tighty, lefty loosey". Then use a flashlight and look for any leaks (this is crucial, so take your time here). Look carefully at both connections and make sure they don't drip... watch them a minute or so each. After that, all you have to do is roll your fridge back and you're done!
Cool, huh?
SG
SOURCE: Ice maker water leak in freezer. 8 yr old Amana
Probably the solenoid (electric valve that opens and let the water from the supply line go into ice maker when It calls for it) is leaking and needs to be replaced ,it's not an expensive job. To make sure this is the problem ,shut of the ice maker by putting up the lever and wait a few hours and look inside the ice maker , if is water inside ,that's the problem ,if not the ice maker is the problem and has to be fix or replaced ; but is better to replace it ,won't be a big diference in cost.
SOURCE: Have a 13 yr old TPX24pr. 1-2 inches of ice formed
Did you find out what was wrong? Mine is doing the same
