3.5v standby power is present on pins when off as expected. When switched on all pins reading Voltage expected on power board, except PWR ON, is reading 3.3v, believe it should be 24V. Not sure if problem is with power supply board or main board.
3.3 is the right reading on the power switch on pin...so the main is telling the power board to turn on like it should be, your power board is bad.
Testimonial: "Replaced power board, did not fix, exact same symptom and voltage readings on power board, blinking red light on front of TV and will not power on. Broke out the heat gun, slowly heated up the processor on the main board, checking temp with IR gun. Held temp between 190-195C for 6 minutes. After cool down TV powered up and is working normally again. Not sure how long it will last. With the price of the new TV's, next time this one dies it will be in the recycle bin."
SOURCE: I have a NS-LCD37-09 tv. No picture or backlight
Your main board is faulty. I've done several of these but haven't been able to figure out which component is actually bad these yet. I've simply had to replace the board itself, and it fixes it every time. One thing you can do to get your backlights to come on (and so you know I'm not Jive'n you) Is unplug the three wire bundle that spans from power supply to main board. This will usually make the backlights fire up. I even had one that after I left it that way for a minute (with the backlight on) it suddenly started working again! But this was short lived. :-(
One time I even tried recapping the entire main to see it that would fix it. It did not. I think it might be something to do with the small chip labeled SL37HA37. It's a 16 legged bastard near the 3-wire plug I told you to pull. It's that or possibly the bigger IC near it that has a heat sink on it. The ball grid array solder joints may be faulty. Just guesses, if any smart guys out there figure this one out, be sure to tell the rest of us please!
Thanks, Chris
Boise LCD
www.boiselcd.com
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
http://www.coppelltvrepair.com/search?Q=l42hdtv10a&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
SOURCE: about the Sony Bravia Kdl55hx800 55" Lcd Tv
The 12 volts comes FROM the power supply board.
TV Parts Universal TV Stands DLP Chips ShopJimmy Go to this web site. You will find repair parts kits as well as complete boards there.
SOURCE: How can i fix LG 50LA6210 with no picture blinking power light ?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
So was it the power board? Where can I get a new one?
